Bookshelf v floorstanding speakers
stevee1966
211
8
18,795
I was just about ready to purchase a pair of B+W 685's for new system but have just seen an offer on a pair of Monitor Audio Bronze BR5's, so i could get them £25 cheaper than the B+W's. Which are the better of the 2 speaker sets ?
It depends on what suits your room.
The BR5 aren't massive therefore you could probably get away with them in limited space though.
What you need to consider, as a simplistic view, is that they are roughly the same price but the BR5 gets an additional driver and lots more cabinet. Therefore is a quality compromise made?
Listen to them both. Sevenoaks stores should have both to compare.
Hi Stevee. . . .a couple of quick questions really. a) can you accomodate floor standers? Are they going close to a wall? usually, not always, stand mounted monitors are slightly more receptive when situated close to a wall (IMHO). b) Have you heard these speakers or are you going on reviews alone? Because these are different in presentation, and as we all know, the ideal sound is a very personal thing.
Personally, I would plump for the BR5's. . .but what do I know?
[quote user="stevee1966"]I was just about ready to purchase a pair of B+W 685's for new system but have just seen an offer on a pair of Monitor Audio Bronze BR5's, so i could get them £25 cheaper than the B+W's. Which are the better of the 2 speaker sets ?[/quote]
The ones that you think sound better...
JoelSim
767
It depends on what you value. Bright top and mid from BR5 or tight bass from B&W. And of course how big your room is/shape of it etc
fr0g
445
erm dont buy blind...unless you live on a remote island. It entirely depends on what suits your amp, and your room.
