I could advise quite a few but not knowing your budget or anything else you really must audition some for yourself.Just reaching out to get some guidance on a pair of bookshelf speakers to pair with a pioneer SX535. Been looking at monitor audio BR/BX and Q3020i. Any recommendations on pairing would be appreciated?
Ok thanks for that. Budget would be below €500, any guidance on efficient bookshelf speakers at that price point?I could advise quite a few but not knowing your budget or anything else you really must audition some for yourself.
Just buying second-hand stuff on someone else's say so is a quick way to disappointment.
However, with only 20wpc , you better be sure they are pretty efficient.
Sorry. I am in the UK and no idea what you can get for that budget wherever you are.Ok thanks for that. Budget would be below €500, any guidance on efficient bookshelf speakers at that price point?
Probably the Wharfedale Diamond 12.2?I am close to the UK and happy to buy from there, for an equivalent up to £450 is there anything you might consider?
In that case the 12.2 are certainly worth a look as are Triangle Borea BR-03Thanks for that. Room is small and space is limited so floorstanders wouldnt work.
