- Aug 10, 2019
- 2,556
- 5
- 0
Having owned a full HD Sony TV for a couple of years and enjoyed the HD content fromSky, I've decided that now is the time to take the plunge and get a Blu Ray player. The remainder of my home cinema system is about 12 years old now, and I know it needs updating but I can only do it a bit at a time. My amp is a Yamaha DSP-A592, and due to it's age I need analogue 5.1 output from the new player. I thought this was going to be simple but having narrowed my potential selection down to 3 I find that all of them seem to have potential pit falls if using the analogue outputs, (if articles on the net are to be believed). The 3 are;-
Sony BDP S550 - seemingly I may have problems getting sufficient sub-woofer output
Pioneer BDP 51FD - Does not decode all the formats into analogue
Panasonic DMP BD80 - lip synch problems if tv is connected via HDMI and analogue outputs are used.
Can anybody tell me if these problems do exist with these players, or if I can 'get around' them, and if so which one should I go for, (or indeed is there another one I should be considering?).
Or is the bottom line that I should upgrade the amp first, and wait before going over to blu ray. All helpful suggestions gratefully received.
