- Aug 10, 2019
- 2,556
- 4
- 0
Hello,
I have the amplifier NAD C355BEE and I'm considering to biwire using or Atlas Cables or the new QED Revelation, but I have heard both and the QED is better in the treble, as for the rest is very similar to the Atlas Hyper 3.0 cables.
Now my doubt arises: should I biwire using a 2-4 cables configuration using only speakers A, or should I biwire using a 4-4 cables configuration using both A and B speakers? Note that the QED is rather thick and a 2-4 cable configuration is kind of hard to make...
My dealer told me to see on the manual of the NAD, but there only says to use the connection of the speakers A as the main speakers in the case of using only 2 speakers or in the case of using 4 speakers to use the A and B speakers, but it does not says anything about biwiring and what configuration of A and B speakers to use.
Please need your advise as to biwire in the NAD C355BEE, for those who has one, what is the tickness of the speaker cable and what biwire configuration you use (if 2-4 or 4-4) and if there is no arm in using the A and B speakers in a 4-4 configuration. Also if using the A and B, will it affect anyhow the quality instead of a 2-4 cables biwired?
J.Costa
J.Costa
