- Aug 10, 2019
- 2,556
- 5
- 0
I am setting up a new home cinema in my 13ft x 13ft living room but don't want to get carried away so have a budget of £1500ish for the lot.
I am set on getting a Playsation3 to handle my DVDs, Blueray, and mp3 music server requirements. It seems to be the best all in one solution if you are on a budget. I am also set on some budget satellite speakers such as the Jamo A10s.
The problem arises with the LCD Screen. I am set on 32" for my room size but can't decide between going for the Sony KDL-32P3020 at £450 or the Panasonic TX-32LZD80 £600. The Panasonic is a bit more compact and has full HD but I have heard that it doesn't make much difference for a screen this size. Is the Panasonic worth the extra cash?
Secondly, I am not sure whether to go for the Onkyo 506 amp or the 606 amp. If my PS3 upscales then what is the point in having the option on the 606? Also, I have heard the 606 can handle HD audio but is this a necessity for future proofing?
Which amp is best for music and will the Jamo speaker and Onkyo combo go well together for Music and Movies?
