Bi Wireing
Nadeac
69
Is it worth using biwired speakers on a non biwire amp ,if so how do u connect up ?
Thanks Mark
you join the wires together at the amp end, + to + red / - to - black. I prefer single wired.
Or you can terminate the cable with banana plugs so that on one end you have four plugs which plug into the speaker and on the other, you just have the two plugs with the +ve (red) connections tied together and inserted into one banana plug and the -ve (black) connections tied together and inserted in the other. This definitely makes it easier to plug and unplug the speakers in the long term.
