steve_1979
BenLaw said:Steve, all the bold type in the world won't make them try it.
I'll try underlined italics next time.
Pretty obviously, yes it does, that's what 'sampling-rate' means. The question is whether all that additional data makes audio within our hearing range sound better.Craig M. said:A higher sampling rate ( which I think is what you are getting at?) doesn't capture more 'snapshots' per second (or whatever)
BenLaw said:Why won't you take Steve's challenge Cno?
CnoEvil said:The more you look into it, the more opinions you get, and someone with a little more technical knowledge can tie you in knots.
Here is another view which is well put (post 4): http://www.thetradersden.org/forums/showthread.php?t=98769 ....at least it ties in with what (I think) I'm hearing
BenLaw said:I don't buy 'life's too short' - you've quoted from several pretty obscure forums to try and support your view, which at one point or another has taken a fair bit of searching, certainly more than the 20 mins Steve says it will take to do his test.
BenLaw said:It's also hard to accept 'I make up my own mind' when there's an apprently simple test which would mean it is your own mind deciding, rather than the unknowns of different masters being used (as per the interesting harbeth quote on the previous page).
CnoEvil said:BenLaw said:I don't buy 'life's too short' - you've quoted from several pretty obscure forums to try and support your view, which at one point or another has taken a fair bit of searching, certainly more than the 20 mins Steve says it will take to do his test.
Googling, I can do......a couple of minutes at best.
The only reason I can rip my music, is because a RipNas does it all. I really am pretty hopeless regarding computers.
My simple test is good enough for me.
We are not going to agree on such matters, so it would be much easier just to accept this.
You should also make it clear to the WHF testers, that all their references to 24 bit sounding better, are also misguided.
As yet, I'm waiting for an answer to my BR vs DVD question.
CnoEvil said:As yet, I'm waiting for an answer to my BR vs DVD question.
CnoEvil said:Googling, I can do......a couple of minutes at best.
Here is another view which is well put (post 4):....at least it ties in with what (I think) I'm hearing
CnoEvil said:BenLaw said:Why won't you take Steve's challenge Cno?
I wouldn't know where or how to start (technically)....
chebby said:I found out for myself that 320k AAC (VBR) sounds as good, to me, as Apple Lossless for my purposes. My 'raw material' is rips from my own CDs (16bit 44.1khz) and I have no interest in 24/96 files (or higher) because there is so little choice and prices are so high.
What the rest of you get up to is of no matter to me.
However, the tone these debates take is toxic to the forum. The same characters 'parachuted in' every time to lay down the law and set tests (where do we hand in our homework sir?) as if they, personally, represent the only truth possible and should automatically hold some natural authority on the subject.
Of course they don't. 'The truth' in these matters is always what makes the individual happy.
Some people want to pay the premium and use higher resolution files in the same way that some have preferred SACDs to CDs or returned to vinyl LPs (or use valves or prefer active speakers or whatever else is on offer). Good luck and good listening to all of you. Keep buying the gear and keep the industry and the choices going.
I am stubbornly sticking to my autodidactic and selfish ways of using whatever I like in any way I choose that suits me. If your 320k MP3s sound better than my 320k AACs and someone else's 24/96 files sound even better than my Apple Lossless files then well done. You are as happy with your setup as I am with mine.
Stuff the homework, the links, the downloads the tests and the overbearing "this is for your own good, now put on these electrodes", tub-thumping acolytes of 'The One True Way'.
sometimesuk said:Steve,
Thanks for the links, I'll download them and let you know what I find.
sometimesuk said:Regardless of format, if you want better sounding albums, say so here
This is what the people here have to say about 24Bit:
"Traditionally when mastering for final production on CD, the 24/96 master will be “normalized” to 0dB as part of the mastering process. Normalizing the recording effectively introduces digital amplification to ensure the maximum dynamic range offered by the CDs 16bits is utilised. This normalisation is critical for a 16bit recording as any “headroom” in the recording will have a significant impact on the dynamic range. For example -6dB of headroom in a recording would only utilize 15 of the 16bits available.
Unfortunately the normalization process introduces quantization errors in the recording - i.e. some bits of the recording may be unintentionally rounded up or down as part of this process. However the balance between quantization noise and loss of dynamic range is an accepted part of the 16bit mastering process.
At 24bit resolution, the issues surrounding dynamic range are not applicable as a 24bit recording provides an additional 48dB of dynamic range over a 16bit recording.
With Kate’s high resolution downloads we have chosen to leave these recordings at the level they were mixed on the studio tape. We have deliberately chosen not to “normalize” these recordings to avoid introducing any quantization noise as described above. As a result, you may notice that the 24/96 files sound quieter when replayed on 16bit devices such as MP3 players or portable CD players"
Even if the above is an exaggeration, and CD is the paramount of digital reproduction, i.e Its impossible to be improved upon, it seems we would all be better off sound back 60 years are using reel to reel tapes!
I am stubbornly sticking to my autodidactic and selfish ways of using whatever I like in any way I choose that suits me. If your 320k MP3s sound better than my 320k AACs and someone else's 24/96 files sound even better than my Apple Lossless files then well done. You are probably as happy with your setup as I am with mine.
char_lotte said:Agreed. It is all so tiresome, whatever happened to being able to enjoy things.
