Better freeview from HDTV
Is there an easy way of getting a better SD freeview picture on an LCD TV ? My Samsung displays great Blu-ray pictures but the image quality from the built in freeview reciever is worse than my CRT set..
Is there a better solution other than shelling out for Sky HD ?
Try to get as good a signal feed as you can. You might want to consider a new aerial and decent cable
Ive recently added an ixos aerial cable to the end of my normal co-ax, and its certainly cleaned the picture up a little.
You might also consider a mains conditioner like the TACIMA on amazon.
