Best white stand speakers for naim nait 5si
criant
9
hi, which white speakers are perfect for naim nait 5si.
My current setup is:
Naim Nait 5si Audiolab Mdac B&w 685s2 Sub Rel T5 cable wireworld oasis 7
I would like to upgrade the speakers: i come to mind
B&W CM6 s2
Monitor Audio Gold50 or other
listen to much rock country rock and pop
CnoEvil said:
I'd recommend the white LS 50s.
Great speakers but an awful match with the Nait 5si. Headache inducing highs. Metal tweeter and Naim don't mix I think.
Problem is, I don't think Naim mixes with anything, so they were better (IMO), than other speakers that I tried from Linn, Rega and Q Acoustics.
Soft dome tweeter and larger, preferably dedicated bass driver and the Nait works very well indeed. Let's not do the Naim thing 🙂 The Ls50s are fantastic speakers, just not with the 5si.
Neat Momentum SX3i possibly? Bit expensive though. 🙂
Failing that the XTZ's as previously posted, they have a ribbon tweeter but it's civilised. Very good value for money, as is everything XTZ.
Or, indeed the Martin Logan Motion 15
criant said:
thanks for your advice, is there anyone who has heard the cm6 s2? I would pay € 900
I haven't, but they might be bright with the 5si - no idea, though, audition if you can. But again, go for XTZ if you can afford them with the upgrade.
K series might suit, and I believe that they have an active module if that interests you.
chebby said:
ChrisIRL said:
White Guru Juniors. Said to be a good match with Naim. Very hard to find though.
That's because Guru went out of business.
i thought they were just doing a factory refurb or something? Pity, they were meant to be very good speakers.
the dynaudio are the Excite x18
summing, the choice is
B&W CM6 s2
Dynaudio Excite x18
Kef LS50
favorite artists: Dire Straits, Pink Floyd Guns n roses David Bowie for rock country
Diana Krall Adele Norah Jones
thanks for advice
I agree with the post not to go with Kef ls50's, as Naim gear needs to be tempered with a softer sounding speaker or not too analytical as the mating between speaker and amp will sound too dry and or harsh especially on poor studio recordings. Recommendations are: Q-Acoustic speakers, especially the Concept 40's (Floorstanders), **Q-Acoustic speakers are all availabe in white. Additonally any speakers from Proac and PMC. Avoid speakers with metal dome tweeters and stick with ribbon and or soft dome tweeters. Basically if you have an amp that has decent attack, clean and clear with some punch then go with similar speakers to blend accodingly. But metal dome tweeters are only going to sound good with laid back gear, like Monitor Audio with Arcam, not my personal taste but its a good match, or in my case Naim Nait 5si with the concept 40's in black gloss, very nice, using arcam ir dac and all Naim cabling, match made in audio heaven.
