Sorry about the blank post!
Here goes again - I want to pipe music from my M-CR603 in the living room to the kitchen, a longish run of 15m.
Should I just hook up a second set of speakers to output B using a long run of speaker cable, or should I be looking at running some shielded cable to a second amp in the kitchen, to minimise the length of speaker cable. First option preferred for simplicity and cost, obviously.
Second question; assuming I go for speaker cable; what cross section should I be looking at to minimise the effects of cable resistance? Speakers are likely to be Q acoustics 2020i or Dali Zensor 1's. Both have an impedance of 6 ohm.
Any other advice that doesn't involve the use of snake oil would be most welcome!
