I have just started collecting the individual components to create an Aviano 5.1 setup.
Currently I have bought x2 Aviano 1's and Aviano 5, which I am running as front and centre.
Then I will add on the Aviano 8's for front and switch the Aviano 1's to the rear surround.
(although I'm aware that Aviano 6 at the rear might be a better option if I can afford to switch at some point)
I've purchased a starter Receiver which is great Sony STR-DH510 for about £150 (because it was cheap in Richer Sounds to get me started) After reading things on this forum I have come to realise that it possibly will not be suitable to get the best out of the speakers.
My question is that I am wondering if anyone has a good recommendation for a new replacement Receiver for the following setup:
Aviano 8 (x2)
Aviano 1 (x2) — Should I consider Aviano 6's and lose the Aviano 1's
Aviano 5 (x1)
Aviano 7 (x1)
Thank you
Aviano 8 (x2)
Aviano 5 (x1)
Aviano 7 (x1)
Thank you
