Best speakers for a very small room, cost no object
Kevin1
I wonder are there views on this? The room is 3M X 3M (a small home office). Speakers would be put on a shelf. Amplification Primare I31. Recommendation I have is for a Harbeth P3 (small, closed box - sounded nice inthe shop, but in a larger room), but very open to suggestions - is there better for small space?
MUSICRAFT
Hi Kevin1
Also consider ATC's curved SCM7 monitors. Work well in small rooms and Primare electronics are known to also pair well with ATC monitors.
All the best
Rick @ Musicraft
matt49
81
31
18,570
If you like the sound of the Harbeths, then there probably isn't anything better.
If you prefer a more "accurate" sound, the Audiovector Si 1 series is worth a try.
If cost is really no object, there are the Wilson Duettes at around £9K.
Or maybe the small wall-mounted Magneplanars with a sub?
I'm sure there are other ideas out there.
:cheers:
Matt
James7
7
Audiosmile Kensais perhaps. Less expensive than some of the other suggestions but lovely mini monitors
Singslinger
16
The new Spendor D1 looks interesting, though I haven't heard it yet.
The Harbeth P3 ESR or the ProAc Tablette Anniversary would be worth auditioning,
Anatta
ATC SCM19 mk2 or new SCM20 (when they're released); don't worry about their size, they won't overpower your room with bass.
Or maybe a Magico Q1, if cost is really no object.
DocG
54
When reading the title of your thread, I thought of the Wilson Duette right away. Then again, I think of the Wilson Duette most of the time, nowadays... :)
I also second Matt's other suggestion: Magnepan. The Mini Maggie system, to be exact. Magnepan uses a Wadia 151 Power-DAC for home trials (for customers who have no amp yet), so the Primare should do well with the Maggies. But I'm not sure if you can demo the system where you live.
Also designed for use on a shelf are the Guru speakers; both the Junior and the QM10two deserve an audition IMO.
gasolin
Mabye these http://www.whathifi.com/review/dali-mentor-menuet or those speaker which use primare amps (very expensive) http://www.system-audio.com/_en-GB/loudspeakers/compact%20speakers/SA_pandion_2/SA_pandion_2
DocG
54
I demoed the Pandion 2s recently: very nice speakers, but they do need some room to breathe.
Frank Harvey
567
Sonus Faber's Toy should work really well in that space, and you could also look at their Venere 1.5 too. ATC's SCM7 and SCM11 (old or new) are another option, and as mentioned previously, Neat's Iota.
gasolin
Some other danish speakers you might like http://www.dali-speakers.com/en-US/Loudspeakers-1/EPICON-2.aspx or http://www.raidho.dk/speakers (Why the ... can't i make my links so you just click on them)
RuudS
My room is about 4x6m and I bought the Sonus Faber Olympica 1.
They look great and sounds very fine.
