Best Phone For £100
  • Start date
Deleted member 2457
Hi you guys, what is the best phone for about £100 and it has to be very easy to use. I am just starting my Xmas shopping. Cheers
Presumably as it's for a present you want a brand new phone?
Deleted member 2457
Hi, yep.
Just seen the Nokia Lumia 610, which reads like it is easy to use. Any more suggestions? Cheers.
Deleted member 2457
I have also seen the HTC Salsa and Samsung Galaxy Ace. Ease of use is my main priority.
Deleted member 2457
Think I have decided on the Nokia Lumia for £80 with upgrade. Good choice? :quest:
fr0g
445
It depends who it's for. Obviously as it's a defunct OS there will be no upgrades and possibly future apps won't work well.
But it's a good device and easy to use.
So it depends on the person...Someone interested mainly in a phone/young/ etc then yep, I could recommend it, but someone older who is more of a gamer then there are a number of cheap Android devices under 100.
Deleted member 2457
Cheers Frog.
Deleted member 2457
roger06 said:
I bought a Galaxy Y as a stop-gap. Hate it...
Yep, I think I am keeping away from the Samsung's, the person I am buying for has a cheaper Samsung than the Y and just can't get on with it either.
Deleted member 2457
I think the Nokia Lumia 800 might be in contention too, does anyone know the difference in terms of ease of use between it and the cheaper 610? Cheers.
Bertie1
Hello Gel.
Recently got an 800 with upgrade,1st new phone in about 4 years and it's my first smartphone.
Very little by way of instructions but I'm up and running with it & like most modern tech it does give a few tips when starting.
Menus are good and you can find your way around
I use it for a bit of everything,not heavy teen social or business use, no gaming and it works fine but I suspect the battery is not the best + it's built in so can't be changed.
16gb and no memory slot so you're stuck with that.
I like it but I'm not desperate about a mobile just need it to work and it does for me.
Deleted member 2457
Bertie1 said:
Hello Gel.
Cheers Bertie, that is great - thanks!
Deleted member 2457
I think I am on the Samsung Galaxy Ace at £80 with upgrade now. I saw a Sony also today that didnt seem too bad.
Deleted member 2457
mark2410 said:
huawei g300 still is the best for a bit under 100
Hadnt heard of this one, so I have just been checking it out, reviews rate it very highly, cheers!
Joe Cox
Content Director, What Hi-Fi?
Staff member
May 31, 2007
275
16
18,895
The Windows Phone OS is certainly very easy to use, so as a budget phone for basic 'smart' usage the Nokia 800 sounds like a decent bet. Haven't seen that particular one though...
What about galaxy Ace. So far more than Nokia and Samsung, Samsung galaxy has a food reputation according to my knowledge. One of friend is suing the phone for pass few months and still it’s in a good condition. :)
MajorFubar
690
8
I've just bought a couple of those for my kids for Christmas, on contract from Carphone Warehouse. £7.50pcm, decent minutes, stupid amount of texts (5000 I think!) and reasonable data. I've put a £10pcm limit on them too, so no nasty bills.
I've not played around with them much, but from what I have seen, they seem reasonable phones. Only two gripes, one being that the video capture is way below par (320x240, like something from the Ark) and no front-facing camera.
Deleted member 2457
I opted for the Galaxy Ace, got it for £80 in Phones 4 U in the Currys Megastore and got a free £10 top up, so £70! Not bad going!
