Best Budget Projector??
Looking to spend around 4 to 6 hundred pounds on a projector. Will only really be using it for movies and xbox. My room is about 18ft long and is quite dark. I had been looking at the infocus x9 however it has been discontinued. Any advice would be greatly appreciated
matt
If you can stretch to just a bit more I would wholeheartedly recommened the Panasonic PTAX200E. I had on eof these before my current Sanyo PLVz700. The panasonic is very bright at 2000 ANSI lumens and provides a superbly bright and colourfull image. It takes 1080p input signals and has a quick response gaming mode. I am very confiident that you would be happy with it
When I bought mine about a year ago I got it for about £675.00 on offer at Dixons Direct You may have to shop around somewhat to get near that price now though. I firmly believe you would appreciate the additional quality spending a little more would bring
Had been lookin at something a little cheaper but will have a look at that and see what price i can get
