Balanced interconnects
JoelSim
767
Now I have a balanced system, any thoughts on what I should go for?
No cable wars please. Am also more than happy to buy 2nd hand so any links appreciated for good stuff.
Joel,
Currently, the Jean Claude Van Damme Classic Black Microphone cable is working well for me. If you see my earlier posts, you will note that it has successfully seen off the challenge of Gotham and GA Coalesce cables. It is dirt cheap and cheerful and matches RCA interconnects many £10s more expensive. Well worth a try. Don't be put off by its appearance and bargain basement price.
JoelSim:
You will love my cables - got them from a store in the US via ebay.
I paid a little over £100 plus shipping (they were ex demos - all boxed with warranty). I'll try and get the details of the shop.
The link below shows what they cost over here.
http://www.sightandsounduk.com/product.php?productid=17715&cat=340&page=1
JoelSim:0.5m is all I need.
You can get 0.5m - £310 at from that website though. The US route is the way forward. The company is called Ultrafi - I've just looked at their website and they are moving this month to another site in Milwaukee and will not be open until August.
JoelSim:Those I/Cs! 48 Volts surrounding them and battery packs.
Let's have a look...
Mmm, lights, batteries. Lots of 'play value'. Shame they have to be at the back of the equipment out of sight.
This is exciting stuff too...
"Similar to how the earth's magnetic field makes all compasses point north, the AQ DBS system creates an electrostatic field which causes the molecules of the insulation to all point in the same direction"
Joel, you simply have to get them!
JohnDuncan:And they are green and black - how much more chocolatey could you get?
Hotel Chocolat?
Apart from the rather natty thermal lagging, they look like weapons pods from a sci-fi film.
My vote goes to the Niagara version at £990 (I'm glad to see that includes delivery!) Do you think I'll hear much of an improvement over the Van Dammes? I wonder if they do a sale or return home audition?
I'm not intending to spend anything on these I/Cs, whatever I get for my Heimdalls will be used and the spare money banked.
JoelSim:I'm not intending to spend anything on these I/Cs, whatever I get for my Heimdalls will be used and the spare money banked.
Hear! Hear!
Joel,
Balanced is for long distances.
For that length you will be fine with an unbalanced cable.
A fiver should get something well made.
Taylor74:
Joel,
I don't have a fiver, but there's a £100 mote burning a hole in my pocket. Spending a fiver would cost me more in the long-run as there would always be a nagging feeling. Plus it will be a fiver lost. The way I do business is to only buy stuff which has an equivalent or better sell-on value a few months/year or two down the line. I bought a cheap I/C once and it went straight in the cupboard after a 15 minute test. I think I lost £8.99 plus P&P on that. Never again.
JoelSim:Taylor74:
Joel,
Interestingly, in my recent experience I found that a cheap Van Damme balanced XLR (probably no more than £30 for the pair, max) is now replacing the Atlas Titan All Cu RCA pair (RRP of 10x the Van Dammes). The differences are absolutely minimal. I also repeat that the difference between the Van Damme XLRs and the GA Coalesce XLRs, at roughly twice the cost, is also minimal.
I can readily understand the view that you need to buy something that will not depreciate in value, but nothing is certain - if I can purchase brand new Atlas I/Cs at £110 a pair that previously cost folk getting on for three times that amount, then I'm afraid you are never going to be safe in assuming that just because you purchased a premium, highly-regarded item, it will hold its value. In this age of the Fleabay the opportunities to buy and sell are endless: take advantage of them. Try something cheap and cheerful off Fleabay and see if it works for you - I shouldn't imagine you would take much of a 'hit' if you sell it on afterwards.
Actually, if you can see your way to buying a pair at £100+ between now and early September, that would be great - a report and recommendation just before I try some more options would be great!
