Hi all,
I'm currently looking for a replacement for my current system (Yamaha AS500 + Dali Zensor 1) as I just moved to a bigger flat and I want to improve the quality the sound.
The listening room is around 5m x 11m. I use the HiFi mainly for music (Rock and some electronic, I like loud volumes.. No neighbours around) only digital input (90% spotify).
Unfortunately there's no way to try the system as I'm living far away from any seller or specialised shop, so I'll just really on your suggestions.
I'm currently looking at the system in the title which is quite a popular choice. My budget is around 2.5k euros.
What I want you to ask is:
Is the Rotel powerful enough to round the speakers or I'm somehow not using them at their best? Should I go with something more powerful or lighter speakers?
Is the B&W bass good and punchy (I read some contrasting opinions in regards) for my needs?
Any other suggestion is welcome!
Thanks,
Riccardo
Thanks,
Riccardo
