AVR Recommendation?
I'm a bit out of the loop as to what's available on the AVR front these days (my Arcam AVR300 does its job fine, though obviously has no HDMI inputs).
A friend of mine has asked for a recommendation for a receiver, but as I've not used any of the HDMI equipped units, I'm not in the best position to advise.
He's currently got a PS3, PC (with HDMI output) and a Sky HD box. He also has a set of 4 Linn speakers.
The requirements for a receiver are:
1. Take a HDMI input from all three boxes, and send HDMI out to his TV.
2. Allow him to set up the system as 4 speakers, no center, no sub (yet).
3. Decode all the Blu-ray sound formats, either from the PC or PS3 (and I presume it's possible to direct sound either to the speakers, or back out through HDMI to the TV)?
4. Accept a digital stereo signal from the PS3, so he can use it to play CDs to two of the speakers (I've not used a PS3, so don't know if you can do that via HDMI, or whether you need an SPDIF or coax connection).
5. Lots of fancy sound modes, upscaling, preouts (other than for a sub obviously) aren't required.
I see the Yamaha DSP-AX763 is the current best buy in the budget range, but it only has 2 HDMI inputs. Is there a suitable 3 HDMI equipped receiver that would be recommended, other than the more expensive Yamaha DSP-AX863SE?
The Sony 820 reviewed on this site is a good option but will be a slight down grade compared to the Yamaha 763 in terms of sound performance. Another alternative is the Onkyo 606 also reviewed on this site.
And then there is also the Denon 1909, but it's only marginally cheaper than the Yam 865SE so it would be worth the extra cash for the Yam
Many thanks for your recommendations. I've passed the info on to my friend, and I'll see what he thinks (or rather, if his other half will let him spend the money
