AVI DM10 Driver
Csw1984
Hopefully some AVI owners may be able help me here - I've got ADM9RS and just wondering if the DM10 driver can be fitted/viable/available from the likes of Falcon Acoustics and other places or was it only made for AVI?
Many thanks.
Roger_A
82
64
18,620
I suggest you try searching the threads on hddaudio.org which will give details of changes between the 9 and 10 series and there are several members on there who have tried swapping drive units from later series. If I recall correctly the biggest difference was to the tweeter which covered down to a lower frequency so the crossover point was different. The bass/mid driver was also different but I can't remember to what extent and as the crossover was different I'd be wary of changing as it may not have been designed to cover as wide a frequency range as the one in the 9 series. However, it's worth asking on the above link. Note that most of those changing drivers were doing so with the tweeter rather than the bass/mid.
