I rather fancy buying the Audioengine D1. I like the way it is usb powered, small, looks good and is pretty affordable. It seems ideal for my needs and will satisfy my itch to buy a new gadget. Not many reviews around on it but from what I have read it seems pretty good.
How much money should I budget for headphones to go with the D1? Would something around the GBP100 to GBP150 mark be suitable or would I need to spend a bit more to get the most out of the D1? I don't really want to spend a fortune on headphones. Any models you can recommend? I mainly listen to pop rock and opera.
Any advice would be much appreciated.
