Audio Note valve amp kit
Crossie
58
Why do I feel an overwhelming urge to buy myself an Audio Note Valve Amp Kit for Christmas? :?
I don't know, why do you feel an overwhelming urge to buy yourself an Audio Note Valve Amp Kit for Christmas? <waits patiently for punchline>
You forgot the "I say, I say, I say" at the start though...
I notice you're using Wilmslow kit, I emailed them about something yesterday, wondering how long I wait for a reply before I start getting annoyed, did you ever have cause to use their enquires address?
Wilmslow have always been very helpful to me.I will use them again when I decide to upgrade my speakers. Hopefully the will get abck to you today.
cheers
crossie
Cool, I did ask them quite a few questions, so I'm happy to wait a couple of days, which valve amp kit was it you were looking at just out of interest?
I love the idea, but the sound will be the opposite end of the spectrum to Cyrus.......and by the time you realize how good it is, you will be hooked, and other AN kit could be on the cards. :shifty:
Go for it, I say.....as a huge fan of AN. :cheer:
If the L1 kit is anything like the Oto, then that should be a good bet, although @ $1400 not the best value considering you can get a S/H Oto for around £900 so not really saving much...
http://www.audionotekits.com/l1el84.html
UK Source:
http://www.hificollective.co.uk/kits/audionotekits.html
BTW Wilmslow replied this morning, we are "in conversation"...
Crossie said:
Are you going to have a go at building your own speakers?
Not as such, see my thread about the Ferguson Radiogram I "found", I'm looking to replace the drivers in that as the mid/bass driver appears to be a 15Ohm unit, which might be difficult to drive with a modern amp (the original amp doesn't work to my knowledge and I'm not sure I fancy 1960's transformers humming away, looks like an inferno waiting to happen! So I'm going to replace that as well.), so it'll be a straight swap into the existing speaker enclosures, I've given them the dimensions and mentioned that the bottom of the enclosure is actually open and the rear panel is flimsy to say the least, so asked them to recommend something that would work in that kind of space.
I highly recommend Wilmslow kits.
Good to know!
hoopsontoast said:
Hang on, you are not planning on using that AN kit in a radiogram are you? :silenced:
You're getting your wires crossed, Crossie is looking at the AN stuff, I'm not (especially not now I've seen how much it costs!).
