Ariston RD11s belt
Shanka
123
I am trying to find a square section belt for the above, does anyone know where these can be obtained ?
Thanks for any help, advice, greatly appreciated
Try here: http://www.elexatelier.com/ariston.htm or here http://www.lpgear.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=LG&Category_Code=A2
Hi Chebby,
Thank you so much, you are a genius.
Have you used these chaps before , all ok ?
Will get the belt then upgrade cartridge 🙂
Thanks also Proffski, didn't see your response, hugely appreciated, will let you know how I get on.
Thanks again
