Arcam receiver no longer working
nicholas08
6
It worked for a few seconds, then i turned the volume down and it shut itaelf off. now the relays click and the screen flashes whenever i try to turn it back on. Any help would be appreciated. I can link a youtube video showing the problem if needed.
Did anything change recently, e.g. did you move the speaker wires, or connect anything new? How old is the Arcam?
Check the manual - is there a rest procedure?
Kit doesn’t last forever, so it depends on its value if it’s worth repairing.
