Arcam rDac
nbaptista
18
I am interested in Rega Dac and Arcam rDac, I would like to know if Arcam can compete with Rega.As soon as possible, I am hearing the Arcam,but I wonder if anyone else did this comparative. I know Arcam is cheaper, but I am interested mainly in usb input,and Arcam usb is asynchronous, which for me is great !However , the Rega looks fancier !
nbaptista
18
I´m playing standard files, not high resolution files
But I think asynchronous USB is better than adaptive USB(Rega Dac) so the reason why I´m keen on Arcam!I might be wrong, but from what I hear from people that have listen asynchronous Dac´s, all say this is the future technology!
acalex
73
As far as I know, rDAC USB input is much better compared to the Rega DAC. It is up to 24/96 whilst if I recall correctly, on the Rega is 16/44 (USB input of course). So if you are plannig to play high-res files through the USB input you should go for the rDAC which is a nice sounding DAC, great for its price.
richardw42
299
I just changed my rdac for the Musical Fidelity M1. The new version of the M1 has asynchronous USB. Don't use this but worth considering.
I much prefer the MF but that's my taste.
acalex
73
If you are playing from pc I think the rDAC is the best deal you can get. Cheaper (always important),compact, solid, nicely built, nice sounding and with a very good USB input. It also has big room for improvement and will be easy to resell without losing a lot of money.
SteveR750
750
148
19,070
Not as simple perhaps:
http://thewelltemperedcomputer.com/Intro/SQ/USB_SPDIF.htm
DAC manufacturers are concentrating their efforts on USB because every PC has it, and everyone who has a PC knows how to use and has a USB cable. spdif and toslink eliminates half the population straight away.
Have a look at Hi-Fi Choice March. rDAC Best Buy and Best Value. Much more expensive Rega best in test. Pay your money etc... PS the asynchronous USB makes a hell of a difference on music form PC/Mac
ifor
115
12
18,595
I have both of them since yesterday evening through until 5 pm tomorrow, but I won't be using the USB connectvity. I'll let you know my thoughts. So far I've only listened to the Rega DAC, but I can't get antwhere near CD quality with lossless files streamed from iTunes on my iMac.
Ben123
21
Welcome to PC audio :) With that said i dont own a cd player as the convenience a dac brings is worth the hassle IMO. Im currently using optical instead of USB due pops and clicks. :wall:
The rega dac and arcam dac are next on my audition list so am very interested in your findings !!
ifor
115
12
18,595
Sorry Ben, I can't agree with that!
I sorted the original problem; I had switched Airport on on the iMac. Having switched it off again so that all the streaming is wired we got on much better with the Rega DAC. It sounded pretty good, but still a fair bit short of the CD player. We then swapped thr Rega DAC for the Arcam rDAC. Wow! What a difference. The Rega DAC doesn't even come close and we are struggling to hear a difference between the stream and the CD. The Arcam is much cheaper and much better.
Musical fidelity m1 gets my vote over both the rega and arcam dacs.
ifor
115
12
18,595
OK. I got better sound out of the Rega DAC than on the previous day. I had turned WiFi on on the iMac (it is usually off) and only remembered when the stream suffered a drop out. I turned in off again and the Rega DAC sounded much better, but noticeably inferior to the CD player.
I then switched to the Arcam rDAC. The difference was instantly obvious. The Arcam rDAC is vastly superior in my setup than the Rega DAC. We really are struggling to hear a difference between the stream and the CD.
ifor
115
12
18,595
OK. I got better sound out of the Rega DAC than on the previous day. I had turned WiFi on on the iMac (it is usually off) and only remembered when the stream suffered a drop out. I turned in off again and the Rega DAC sounded much better, but noticeably inferior to the CD player.I then switched to the Arcam rDAC. The difference was instantly obvious. The Arcam rDAC is vastly superior in my setup than the Rega DAC. We really are struggling to hear a difference between the stream and the CD.
ifor
115
12
18,595
ifor
115
12
18,595
