- Aug 10, 2019
- 2,556
- 5
- 0
Hi guys
Following several months of listening to my first proper music system, I have come to the conclusion that the Arcam A32 isn't giving me the sound that I want and I'm looking for a new integrated to replace it...
In my current set-up (Rega Saturn CDP / Rega P3-24 / Arcam A32 / DALI Ikon 6 mk1), the whole thing has too much bass and not enough high mids. It lacks aggression, dynamics and clarity. Certainly, it is warm, deep and smooth, but I'm having to take off almost 5db off bass (in the amp's EQ) just so that the bass doesn't overpower everything else. Also, the sound is too recessed for my liking, and even though the Ikons are big speakers, the whole sound just doesn't sound as dramatic and massive as I would like it too.
It definitely isn't the speakers - since I chose the Ikons for their clarity and tight bass; and the Rega sources have strong bass but not excessively so. Basically I think I don't get along with the "Arcam sound" - I listen to progressive rock / metal / classical - and the politeness and smoothness of the amp's sound just isn't working for me.
Originally I went for the amp because I was aware of the lean nature of the DALI's and wanted to have a strong bass response also. It didn't sound as overpoweringly bass-heavy when I demoed the gear....
Anyway, I would like to have some recommendations on amps to check out. Max budget would be around £1500, but would want something broadly in line with the rest of my components..
Had a look and some of the choices seem to be: Sugden A21, Primare A30, Naim XS, Roksan Caspian, Creek Destiny, Musical Fidelity A5 and maybe some others. Need to have 5 inputs along with a phono input ideally. Happy to consider valve amps if there is anything in this price range...
It has to fit it with my Rega sources and the DALI's.... amp's sound should be musical, clear, with strong dynamics and powerful bass, but mean and raw enough to handle distorted guitars and huge drums! Wide soundstage and aggressive mids - but not too shrill in the treble.
Would really appreciate your input.
Thanks guys!
Roman
Thanks guys!
Roman
