CnoEvil said:
cse said:
Not sure that I totally agree. I've always found listening to stuff at a dealership to be an overated, inexact science. Even when you've spent hours (as I have ) comparing multiple components/system set-ups and finally decide upon a component, convinced at that point that you have made the correct/informed decision for youself/system, you then take the component home, plug it in and are then intstantly underwhelmed. Over time, you then find out, whether or not you have made a mistake. If you have, the informed wisdom is that you need to start all over again, only this time listening even more carefully. Actually, I now believe it doesn't really matter what you choose, after all they all HiFi and ought (within reason) to work perfectly well and be suitably compatible. Generally, I feel, it is best to purchase all of your HiFi in one go (ie amp,source,speakers) and keep it for a considerable amount of time (ie when it breaks) before changing anything and don't (most importantly of all) waste time and money upgrading anything.
I'm sorry that your demo experience has left you so disillusioned, but choosing the right list, going to a good dealer and not then not putting pressure on yourself by assessing too many choices in one go, is key. The winner should then be home demoed if possible.
Done that. (Listen to and compare a list of stuff in a shop, then try out the 'winning combination' at home.)
The problem was that (at least once) a component, even whole systems, sounded the polar opposite in the shop to how it / they sounded back at home. So any short-list would have been totally skewed to stuff that sounded better in the shop and so would the 'winner'. The only solution would be to listen to every permutation of possible components / systems at home and that is impractical on many levels. (Unless you have an infinitely patient local hi-fi shop and stacks of spare time.)
I may be odd, but I don't want to be the sort of bloke who is spending large chunks of consecutive weekends hanging around hi-fi shops getting my head in a frazz over which combination of - say - four amps, four sources and four sets of speakers is best.
I think that's 64 possible combinations to listen to! (And some people consider four choices of speaker, amp and source to be a pretty restricted choice.)
It gets even worse if every one of the 64 possible systems has to be compared (and not just listened to) and downright insane if some of those combinations are split between two (or more) shops.
