Anyone have experience driving Rega R7's or similar. (6 Ohm,125W, 89dB)
therumdiaries
Hi, first time posting, so thanks in advance. I'm looking for a new amp for Rega R7's. Need to replace my now-dead Cambridge Azur 640A which I think might have been a bit of a cold/lifeless pairing to begin with...
  • Rega R7's are 6ohms/89dB sensitivity/125w/channel, so only moderately efficient.
  • Stand alone DAC that delivers all the inputs (Stello DA100) so I don't need 'features'
  • Very moderate listening levels in a ~30m^2 room
  • Listening to everything - jazz, folk, rock, metal, electronica, younameit.
I'm considering the obvious two at this price point... Rotel A8 (€400) which seems 'right' but might only be delivering 35W at 6ohms... Has anyone any experience to share. Is this deal-breaker teritory or don't sweat it and as long as it's enjoyable. The primariy alternate is the Marantz PM6007, moving to ~50W at 6 Ohms. Highly reviewed but on pure sound, which is my base criteria doesn't appear to be quite as tight as the Rotel.
Do I really need to think again given the calibre of the R7's and dig deeper into finances and if so what amps might I be targeting, say at absolute limit of €800 (Arcam A5 perhaps)?
Or just get the Rotel and stop noodling over spec sheets?! : )
That’s actually a pretty good sensitivity by today’s standards but a nice sized room to fill. However, you state very moderate listening levels, so indeed the Rotel might suffice. I’d instinctively look for something beefier but the best way to tell is find a friendly dealer from whom you can buy on a returnable basis, or who might lend you their demo model.
Don’t be surprised if they show you a Rega amp at £2,000 plus however, as that’s a more natural partner for a speaker that cost about £1,500/pr over 15 years ago!
Welcome to the forum!
Reactions: therumdiaries
I will hopefully be able to do this. After all an amp is not just for Christmas.
Edit: I just tried my neighbour's older Arcam A75 and the difference is staggering. Consider the budget doubled. There's an Arcam A5 nearby for €750 and a Rega Brio MK7 at €920 which will have to fall under consdieration.
Oh what difference listening and a few hours can do!
Reactions: Integralista
Hi, first of all wellcome to the forum.
You got very good speakers, Rega R7 is somehow in a class like Rega Aya speakers from current line of Rega speakers. I think R7 deserve even better amp like Arcam A5 or Rotel A8 or Marantz 6007. All of them are very good but not on level as R7 speakers. I recommend to look for a used Rega Elex or Elicit amplifier. Or Cambridge Audio CXA81. I have used Rega Jura speakers with Rega Brio mk6 (previous version) amp, very good combo as well. There is a real synergy between Rega amp, components, speakers. BR.
I would be seeking out a S/H Rega Elicit-R, or Elex-R . Both should give you great results with your R7's. Or if you have the funds consider buying the latest versions. Rega synergy exists !
Thanks for that Integralista. Having had an amp die takes a little confidence out of buying second hand on the open market but I will have a look at second hand through local suppliers. I do love the R7's and can see the benefits.
Thanks Din5. Good call. You hear about these things but so just booked to take the speakers up to a local shop to do exactly that. I'm dying to hear it myself at this stage! Will report back...
