Question anyone familiar with these speakers?
quadrupler
Hello all, hopefully this is the right place to post this.
I came across a listing for these german-made speakers - WHD BR 140-1/8 - for 200 euro.
They seem to be in really good condition and the seller is reputable.
Info online for them is very sparse, but they do have a hifi wiki listing, and some additional specs from the seller, roughly translated:
System Configuration
  • 3-way bass reflex system with front-firing port
  • Reference WHD chassis components
  • 25mm silk dome high-frequency tweeter
  • 43mm silk dome mid-frequency tweeter
  • 175mm grooved special paper woofer cone
  • Removable metal protection grilles
Technical Specifications
  • Nominal Power: 70W
  • Musical Power: 140W
  • Impedance: 8Ω
  • Frequency Range: 35Hz - 25,000Hz
  • Crossover Frequencies: 900Hz / 3,500Hz
  • Color: Black
  • Dimensions (H × W × D): 520 × 300 × 240 mm
  • Weight: 9kg per speaker (18kg pair)
Has anyone came across the brand and/or model?
Assuming I'm able to test them out, would this be a good deal?
OK - and well-observed by JW above!
Personally, I'd be very wary of buying speakers so old. If something goes wrong, you are far less likely to find spares, and I doubt the warranty offered will be long. In your shoes, I'd prefer a trip to a dealer to compare a few new ones.
