Any1 have the sony HT-IS100 system ?
iv had mine for about two weeks now and its fantastic. So easy to use and set up. I have my sony tv, blu ray, ps3, and xbox 360 all hooked up. i have this in my room which is 8m by 8. I your room is bigger i would suggest getting one of sony's bigger systems.
tvspecv:no review here any good?
You didn't look very hard....
Sony HT-IS100 Review
thank you daveh75 do you know where the cheapest system is? and how many optical inputs does this have
tvspecv:thank you daveh75 do you know where the cheapest system is?No idea to be honest, google's your friend i suspect!tvspecv:how many optical inputs does this haveIf you click on the "tech spec's" tab at the top of the review it will tell you.
EDIT-Having just had a quick look, it has 3 optical and 1 digital coaxial connection.
