Andrew Everard I pad question??
john1000000boy
241
7
18,795
Hi Andrew just got an ipad can you use the forums on it with the settings change and still use a macbook at the same time or is it 1 or the other??
John
You can use both with the plain text settings, but it will make it slightly trickier to post links, pictures, etc., on the MacBook.
Thanks Andrew!! Rapid as ever!! Will just leave it the way it is for now i think. Does this mean i will not be able to post/reply on the forums if i use the ipad with current settings??
I'm not totally au fait with the iPad and its browsers, but I gather that 'plain text' is the best setting for posting using iPad; at the moment you are using 'enhanced' settings.
