Thank you 😊 Do you know regarding the Whaferdale Denton 85th Anniversary that has a minimum impedance of 3.8 ohms, if that's ok with the same amplifier (Teac AX-505).Roughly, and close enough not to worry about.
I would say it would not be an issue.Thank you 😊 Do you know regarding the Whaferdale Denton 85th Anniversary that has a minimum impedance of 3.8 ohms, if that's ok with the same amplifier (Teac AX-505).
Note the word 'minimum' there.Whaferdale Denton 85th Anniversary that has a minimum impedance of 3.8 ohms
Too true. The perfect example were my RS6s. Nominal impedance is quoted 6 ohms but it could dip to about 2.5 ohms (IIRC). Shouldn't be a problem unless the amp is low powered.What you need to understand is that the quoted impedance figure for a speaker is nominal.
During use, the impedance seen by the amplifier varies.
An eight ohm speaker, for example, for some of the time will be 6 ohms, it might even briefly dip below 4 ohms.
If your quoted wattages are true for 4 and 8 ohms, then all you can say for sure is that, for the time when the impedance hits 6 ohms, the wattage will be somewhere between 90-130W.
You ask if the amp can run 6 ohms.
If any amp can happily run 4 ohms, then you can be sure it will run 6.
Shouldn't have an issue.Thank you 😊 Do you know regarding the Whaferdale Denton 85th Anniversary that has a minimum impedance of 3.8 ohms, if that's ok with the same amplifier (Teac AX-505).
