- Aug 1, 2019
- 15,627
- 235
- 0
Amazon’s latest Fire TV Stick promises to take 4K streaming to the Max, and it mostly succeeds in doing so.
Amazon Fire Stick 4K Max : Read more
Now explain why that might be wrong. Because it is wrong. The exact same digital signal will give different sound from one device to another. Audio is not IT 🙁Sound out is digital, therefore the quality of the sound will be determined by the connected equipment NOT the stick.
Bill
Digital is only digital in concept. The reality is analogue circuits are used to pass a digital signal. And all analogue circuits make noise. The upshot is two different devices can send exactly the same ones and zeros but sound different. Because the DAC will not only receive the ones and zeros but also circuit noise, jitter, etc. which can get passed to the amp.Digital is digital so the sound will be determined by the external DAC, NOT the unit feeding it.
What I suspect you mean is that different apps on the unit sound different, this however has nothing to do with the unit but is down to the manufacture of the app.
Bill
This is the same reason why e.g. different HDMI cables really can sound different — some of them are better at isolating circuit noise than others. (Though nothing will ever convince me to spend more than £20 on one.)
Can everyone hear it? No. But then some people can tell you what grape, region and even slope where others can only tell you the colour of the wine 🤷♂️🙂
Explanation by an audio engineerIf you can provide verifiable evidence that a good quality cable can sound different to another one, (Digital or analogue) I will have another look, however as no one anywhere in the world has been able to do so , I am not holding my breath.
Bill
View: https://youtu.be/ld68LCIRqQg
As he says, it has nothing to do with the ones and zeros, those stay the same.
Analogue cables are easy to prove, just swap a cable. Though there're definitely diminishing returns. My old speaker cable was fine — supplied by Mission and what they tuned the speakers with. Replaced it with reasonably priced oxygen-free copper and it was a huge improvement.
Again, not saying to spend a fortune but there plenty of people who can hear the difference. Even down to stuff as dumb (to me) as power cables. Thankfully, my ears are good but not that sensitive.
A different audio engineer demonstrates provides verifiable evidence.As I said no one anywhere in the world has been able to provide verifiable evidence that different quality cables affect the sound (Unless badly designed)
Hope that's true because most of the cables-don't-make-a-difference crowd have made up their mind and nothing will change it. All without ever using their ears 🙁however if you can provide verifiable evidence that they do then I will have another look.
Oh now it has to be a "decent" DAC? The ones and zeros might sound different on a DAC that isn't "decent"? 🙄Regarding the video this has been known for decades, which is why any decent DAC isolates this problem making it irrelevant.
Nope, you're just repeating your same bad theory from before which the first video proved is wrong. This has nothing to do with the ones and zeros, they stay the same. This is to do with noise, jitter, timing, etc.(So long as there is a difference between on and off digital will work 100% correctly no matter what shape the waveform, plus its got to to be a pretty crap cable to cause even a small variance of the pulse)
Oooh, so when I show you actual evidence you switch to personal attacks... Classy 😛1. You need to get some basic technical knowledge (You old school science books will do) as you are mostly talking nonsense.
2. You will find that those who say there is NO difference, will have used their ears to see if there is a difference, and in most cases there is, however once you take out the variables (Level matched double blind test) all the differences disappear. (Just because you hear something doesn't mean its actually there, this applies to all the senses as all biological life forms suck (And are easily tricked) when it comes to this sort of stuff.)
3. The second video you posted (GR Research) is the biggest con ever (And disappointing as when it comes to designing and redesigning speakers GR Research is absolutely brilliant) as it uses radio frequency's which react completely differently to audio frequency's.
4. You have still not provided any verifiable evidence (Just your opinion) and so there is no reason to try it out again as the results will be the same.
To finish this conversation I will say what I always say, if you believe cables make a difference (Even when there is no verifiable evidence anywhere) then by all means buy what you like, but don't put over an opinion as fact.
BTW. Psychologically also plays a part (This is why you can hear a soundstage between a pair of speakers when in actual fact it does not exist) but that's a complete other discipline.
Bill
Where did I make a personal attack, all my comments are from fact and experience.
1. I was doing that when I was at school, I have always been one to take things apart to see how they work (And of course I was working with electronics for over 30yrs in my job) to get a fuller understanding.
2. I could tell what was what in my teens, plus I always make sure I go out to watch live bands so that I know what real music and instruments sound like.
3. Nope, it just proves that radio waves have different propagation to audio frequency's and using them to prove something that is not relevant to the audio spectrum is a con. (This is why I said I am extremely disappointed that Danny put out such a video as that is not what GR Research is about)
4. Paul of PS audio has some great videos, although I do disagree with some of them , (This is common between engineers) however the one you posted is good, but unfortunately you have misunderstood most of what he said, hence the reason I mentioned to do a bit of basic research so that you can fully grasp what he is saying. (Unfortunately describing electrical/electronic properties to a layman doesn't always work as you would wish ( I know, as when I was teaching newbies into the trade I had to vary things depending on what knowledge they had)
In a stereo system the only sounds you here are from the speakers and room reflections , however due to the way the brain/ear works, it creates an illusion of a soundstage, but if you walk to that part of the soundstage it disappears as it was never there in the first place, however if you do this with a live band then the soundstage remains no matter where you are , as its actually there.
As I said in my previous post anyone can hear a difference, however biological life forms are easily fooled into hearing (Seeing, feeling smelling) something that is not there, which is why I always make sure that when I do hear a difference, I make sure that anything that could be fooling my senses is removed, and in 100% of cases the differences disappear. (That is the only way to make sure that what you are hearing is real and not imaginary)
Anyway time to put this to bed as it is going nowhere.
Bill
Bill
