- Aug 10, 2019
- 2,556
- 5
- 0
This forum gave me many invaluable informations about PC-based music in the last several months. However, my brain is frying now, and I desperately need some input from (to me) wery well known posters on this forum. So, long story made short:
I have a 2.5 years old Laptop FujitsuSiemens Amilo Li1705 with Intel Core Duo T2450 2.0 GHz, 1 GB RAM and 160 GB HDD, run by MS Windows XP Professional version 2002 Service Pack 3. Soundcard is VIA High Definition Audio (Compatible), and the graphic card is VIA Chrome9 HC IGP. I also have WiFi 'g' home network for surfing the net.
Laptop is connected to the old Kenwood Solid State Stereo Amplifier KA4000 (170W) via 3.5mm phono out to stereo RCA to the amp, and then to the Kenwood KL-555A 3-way 4 speaker system (2x90W speakers).
I have 69 GB of low-bitrate MP3 music, but already started with FLAC downloads through m-torrents. I have downloaded Foobar2000 v1.0 and it will be my preferred music player instead of Winamp and VLC media players. I plan to buy 1TB external HDD for storing the FLACs.
WHAT DO I HAVE TO DO TO IMPROVE MY SOUND? HERE IS WHAT I THINK I HAVE TO DO - PLEASE BE PATIENT IF SOME OF THE QUESTIONS ARE STUPID, AND PLEASE BE GENTLE WITH THE ANSWERS
1.OS: How to bypass Kernal Mixer? How can I find if my soundcard supports ASIO? Do I need ASIO or ASIO4ALL? I downloaded both, but don't know what to do after this? Will ASIO/ASIO4ALL disable volume control/DSP or shall I make it manually?
2.SOUNDCARD: What changes should I make in settings, and how can I be sure that it's STILL not resampling from 44.1 to 48 kHz? Will external DAC completely bypass the soundcard, or is there still a chance for resampling? My Laptop do not have coax or optical out, bit it has 3 USB ports, so I guess I will be limited to 16-bit music and could have potential brooming sounds if the power in my home is not sufficiently clean?
3.DAC OR LG BD390 + CONNECTIONS: I know external DAC like CA DacMagic is the obvious choice, but what do you think about Blu-Ray and media player like LG BD390 (in terms of functionality) for similar money? It has 24bit/192kHz upsampling which sounds good, has WiFi 'n' and is DLNA certified. How to conect PC to, say BD390 - USB, Ethernet or Wirelessly (can I stream 24-bit music through Ethernet and/or WiFi)? Do I still need to bypass KMixer if I stream wirelessly?
4.MUSIC SERVER/MUSIC PLAYER/WIRELESS STREAMING: Here I am totally confused. What is the basic difference between server and player? Asking at the LG shop, I have learned that BD390 comes with Nero MediaHome 4 Essentials server software, and now I don't know if I should use this server (and is it any good) or Foobar2000 player for music, or can I use both?
Sorry to be SO thick, but these questions are hanging over me for months, and I am already spending half of my working hours on these forums, so it must come to some finalisation somehow!
Thanks in advance,
Goran
Thanks in advance,
Goran
