- Aug 10, 2019
- 2,556
- 4
- 0
Hi everyone,
I did look through all the posts in this section, but I could not find something that provides a suitable solution....
I currently have a DacMagic connected to a hybrid integrated amplifier (Valve Audio), to this I have connected a Pro-Ject Head Box II. The best solution I have found so far is to connect the DacMagic to the inputs of the head box and then the outputs of the head box to my amplifier. The Valve Audio amp does not have a headphone out....
I use a pair or Grado SR80i headphones.....
I found that if I used the tape out connectors on the amplifier, then I was not getting much sound through the head box.
So my questions are as follows:
I would appreciate any feedback...
SM
- Is this the best solution?
- This is first time that I'm using a headphone amp, so does this set-up hamper its performance?
- Was there something I missed when using the tape out connectors?
SM
