- Aug 10, 2019
- 2,556
- 5
- 0
Hello eveybody,
I really need an help from audio gurus like you guys.
I working on an audio setup for a quite small room (just a sofa, a table)... a room where to relax myself.
Audio comes out from my mac (I almost ripped at maximum quality all my CD collection), then enter into a Yamaha HTR-6030 Ampli (I find it a good all around amp the use) then ... I need a suggestion for the speakers.
(a) first question: the room is small and the only zone where i can put speakers doesn't allow stereo separation (I mean if I want to put 2 speakers, I almost have to put them at 10 cm distance from each other), so I was wondering what about using just one speaker. Is it possible panning out all the signal from the amp to the left or in another way?
(b) if it is possible what do you think: considering the room I have, and the budget (250-300$) better just one better quality speaker or two cheaper ones?
(c) any particular suggestions on sepakers (i love woodden speakers). I tought about a B&W cm1 (but I can afford just one), or a couple of tannoy (there are some cheaper models), others
Sorry gor being so long and for my bad english. I just try to be as clear as possible.
I really need a good advice from you.
Thanks a lot in advance.
Lorenzo.
Lorenzo.
