6ohm fronts & 8ohm rears, Yammy RX-V1067 do i change the output settings?
Recently bought the RX-V1067 and am very happy apart from the rears not producing much volume. Just had a look, and the Boston VRS Micro rears are 8 ohms, and the MS BR5's are 6 ohms. now i know i read somewhere that the amp can be changed to drive different resistive loaded speakers, but i'm sure it is a general setup for the amp, and not channel specific. If that the case, do i leave it as it is or change the amp to the 6ohm output setting. Would i gain anything, or destroy something?
Your help would be appreciated.
Leave impedance settings as it is and up the levels on the rear channels. The autosetup does work but in the end, it is always worth making manual adjustments.
