- Aug 10, 2019
- 2,556
- 5
- 0
I understand that the numbers refer to the number of DISCRETE channels being produced, so I believe that the 5.1 means front and rear left and right, center front plus a single mono sub bass channel. 6.1 then adds a discrete center rear channel. SO FAR SO GOOD. However we now get to the 8.2 system. Assuming this is just adding a further 2.1 channels to the 6.1 system, where do these next 3 channels go? On my Yamaha system these extra 2 are high level mounted, front effect speakers and the extra .1 is a second sub channel. Now is this front and rear subs or left and right, I have seen both. I also have 3 sub pre-outs, mono, left and right, but most diagrams I see show front and rear. Which is it? I have also seen those extra 2 channels as mid-way between front and rear, ie side channels. So is 10.2 then front efffects AND sides, with stereo subs or front/rear subs. And where the hell do we get a 7th channel from without losing the center rear? Is there no fixed format or is it all getting a little silly?
