26 inch or 32 ich for PS3 gaming which would be better?
The bigger the better! Or, whatever your eyes can take. A screen to big for your room can seriously mess your eyes up.
Get the biggest size screen you can afford, you won't regret it! When it comes to games the more you can see the better, afterall you don't want to be sitting infront of it squinting all the time lol.
A 26" would suffice i'm sure but i'm absolutely certain that you would regret not buying the larger screen, the big question is how far away will you be sitting from the screen? If you are going to be quite close then a 26" may just suit otherwise it's the 32" for sure.
U need the biggest monitor u can.
For example I used to play GTA IV on a 24'' tv and the tv was too small to read the messages or see the map clearly.
Now I use a 46'' tv and its so much better - almost like a new system.
The same 4 me for hd gaming better to have a larger monitor as you will have to get in front of the screen to see small words, etc.
I would go with a 32",look around for some good deals for the sony bravia 2009 range,A bravia matched with your ps3 will look stunning.
