Your suggestions on improving SQ
Hello everyone,
I would kindly as for your suggestions, as i am new to HI-FI and I've got a feeling that my speakers and receiver can do better with stereo :) As i audited Yamaha rx-a 810 receiver in the shop and the sound was richer and better soundstage. As well as when I audited my speakers at seller's place they were doing very well. So it must be something in my current setup.
My specs:
Speakers: B&W 685
AV receiver: Yamaha rx-a2010
Source: PC soundcard Asus Essence One ST RCA
RCA cables http://www.techlink.uk.com/products/wires_cables/wirescr/wirescr_video/wirescr_rca_phono_plug_to_rca_phono_plug
Speaker wires: Classic White W250 2,5mm [/b]http://www.norstone-design.com/en/model/78_Classic-White.html
Software: J.River 16 ASIO
Music format: FLAC, wma
As you can see I am kind of low budget but still able to spend couple of hundreds on cabels, wires or dac (in case of dac budget can strech over time).
What should I be concentrating on?
Thank you in advance!
BR,
Simon
richardw42
299
Yamaha Receivers have pretty good dacs. Can you connect to the amp with an optical cable.?
A fiver will do it, don't go mad with cables yet.
ellisdj
377
Hello mate
couple cheap upgrades - firstly the opamps on your sound card / dac can be upgraded - the LME49720 is recommended for the asus essence stx so I am sure it will work great in the essence one - you will need a lot fo them lucky they are very cheap
This is a much better option than using the dac in the Yamaha - the Asus soundcards / Dacs use fantastic high quality burr brown dacs, itsa the opamps they use are cheap ones. Upgrading them will make a very big difference - there is loads onbline about it
The LME49720 was 2 years in its design - solely designed for high quality audio - where most other opamps arre intended for other uses then used for sound applicaitons
check out frugalphile who sells them presoldered from America on Ebay - I have bought a couple off him and they were perfect and arrived within a week - I have no affiliation to him
Second upgrade - get JPlay upgrade for J River - its 90 euros but takes Jriver to a completely new level - its a very good player / source, I mean very good - total expenditure £150 max and that will take your system up a big level and your knowledge as well ;) You can download a demo before you purchase jplay to test it as well before you buy
Thank you for such a fast answer!
This is a very interesting suggestion for me. As i had read somewhere that s/pdif cables are very limited in data transfer speed. I tried to find this article but found pretty much opposing information :) But i will definitely try it. But what would be better: i am going to buy HDMI graphics card for PC anyway to connect it to the reciever, so shall i use s/pdif with my current sound card or having HDMI connection with graphics card?
Thank you very much for you time!
BR,
Simon
Thank you ellisdj for your suggestions as well,
This is becoming interesting, ill do my research :)
BR,
Simon
