- Aug 10, 2019
- 2,556
- 4
- 0
Hi
I have been looking at these two models of amps the yamaha V667 and V767 I have found the following difference between them:
V767:
I can't get to demo them both so I would like some opinions if the 767 is worth the extra £60 I know I wont use the 2 HDMI's but if the sounds is noticeably better than the V667 then that alone would be worth it to me.....
Other recomendations would be great but I hear yamaha amps go perfectly with Monitor audio speakers? are they warm/bright sounding? I like clear clean dynamic sounding audio but not grateing or anything that makes your ears whistle with tinitus after 5 mins!
Thanks guys
V767:
- Little more power
- Slightly taller
- Learning remote
- Vocal hight adjustment
- 2 HDMI
Thanks guys
