- Sep 22, 2011
- 27
- 0
- 0
I own a yamaha as500 hooked with kef Q100 . Couldnt find out whether its warm or bright?
What sort of speaker will go with yamaha as500 warm or bright?
audipheonix said:Actually when listening to pink floyd it sounds good but listening to Linkin Park it sounds horrible, the sound gets muffled and disorganized is this the amp's fault or the speakers are not capable enough?
PhilBlvdElec said:I also own the Yam, I was instantly seduced by the sound of "softer" music... Radiohead, some local folklore bands, some classical music, all that sounded wonderful, detailed, and way smoother than anything I expected at home (did not demo the system at home before buying it, all hard surfaces in a small space)... A little on the clinical side, which I don't dislike myself, carefully chose the speakers accordingly to that taste (BX5). CDp is Marantz CD6004, and it just matches perfectly with the Yam. So just like Cno mentionned, could be a good thing to upgrade your source.
But that being said, I knew the real test would come with "heavier" music... so upon experimenting, I listened first to the Lost Highway soundtrack, seemed appropriate for a gradual appreciation, mixing many musical inspirations and styles. Bowie "I'm deranged", then Nine Inch Nails "The Perfect Drug"... Smashing Pumpkins "Eye", Lou Reed "This Perfect Moment", then a couple of accoustic tracks, and then Marilyn Manson "Apple of Sodom" and "I Put A Spell On You"... and then Rammstein. I was amazed. Better than anything I had in mind, it seems the system could handle anything - in my very humble opinion at least. Also listened to some trance and techno my brother brought on New Year's Eve. Yet again, it was all perfect. Only band I did not dare to test yet is Slipknot. Well, that's just the type the wife won't handle, so I'll have to wait for a better timing! 😉
All this to say that you should be able to appreciate some Linkin Park through that amp... In fact I did... and like it was said here, the speakers are the least important factor in your setup right now. So that leaves the source...
