Yamaha A-S500 + 2.0, furher upgrade to 2.1
LiquidDB
Hello
Sorry, for bad English.
Amp is Yamaha A-S500. Please, advise speakers for music(all genres) and movies.
Options to which I looked:
1) Dali Lector 1 398 USD
2) Dali Lector 2 490 USD
3) Tannoy Mercury v1i 310 USD
4) Wharfedale 121 270USD
5) Wharfedale122 350 USD
6) Monitor Audio Bronze BX2 490USD
7) Your advice
Further, when will I get extra money, i'd like to upgrade 2.0 to 2.1
1) Wharfedale SPC-10
2) Your advice
It is clear that the set must be agreed.
So, waiting for your recommendations. Thank's a lot!
With that amp you'd be better off going for a pair of floor standers straight off.
Have you considered the Dali Zensor 5's they have good bass response and would negate the need for a sub, also worth considering the MA BX5's. Both these speakers are slim and will have a smaller footprint than the stands you'd need for the standmounts you've listed and save on the extra cabling and room taken up by the sub. they may also save you the cost of a musical sub.
Check the sales seeing these at around 450 english pounds at this time - if thats within your budget its worth considering.
Thank's, Thompsonuxb!
But this floor standers doesn't accepted to me, to much expensive - Dali Zensor 5 - 842. And the most of floor standers - over 700 in my country. One more little notice, speakers with rear oriented reflex port - doesn't acceptable to my room interior.
as mentioned above, floor standers would be ideal since they have been designed to hit lower end notes and it should sound a lot better than trying to match bookshelf speakers and a sub (allbeit the sub can get even lower)
i would strongly recommend q acoustic 2050i speakers. In my home cinema room, i have 2050i and the matching centre. I dont need a sub since the floor standers do a great job so i saved money on a sub.
2050i can be had here for £400 now. not sure how much they are in your country.
Thank you, gurjitsidhu
But in my country 2050i price starts from 1140USD (705 GBP) - tooooo much expensive. It's over budget 2 time's.
Relative cheap floor standers: 1) Magnat monitor supreme 1000 - 535USD 2) Mission MX 3 - 580USD 3) Wharfedale 10.3 - 505 USD
Other good offers starts from 700$ it's overbudget to me. Thats why i'm looking for bookshelf speakers.
