plastic penguin said:Should be fine with PMCs. Although, (as JD alluded to) with a 30 watt per channel, may struggle at higher volumes.
However, Rickcraft is being over zealous with his appraisal about Qute/PL200. If you look at the spec sheet http://www.monitoraudio.co.uk/products/platinum/pl200/#/specification, they recommend amps 100 watts upwards.
bigblue235 said:plastic penguin said:Should be fine with PMCs. Although, (as JD alluded to) with a 30 watt per channel, may struggle at higher volumes.
Seems a bit harsh that someone who hasn't used this kit is telling an experienced dealer, who has actually used this kit in tandem, that he is 'over zealous' because he doesn't agree with recommendations on a spec sheet?
MUSICRAFT said:plastic penguin said:Should be fine with PMCs. Although, (as JD alluded to) with a 30 watt per channel, may struggle at higher volumes.
Hi plastic penguin
What would you say about using a Krell KSA-50 (50w/ch) with PL200's?
All the best
Rick @ Musicraft
John Duncan said:Back to the OP, I'm hooking a Qute up to a Serve with DB1is this afternoon, so will let you know my findings.
chebby said:John Duncan said:Back to the OP, I'm hooking a Qute up to a Serve with DB1is this afternoon, so will let you know my findings.
plastic penguin said:MUSICRAFT said:plastic penguin said:Should be fine with PMCs. Although, (as JD alluded to) with a 30 watt per channel, may struggle at higher volumes.
Hi plastic penguin
All the best
Rick @ Musicraft
The Krell was about 2k in the early 80s. But no I wouldn't. You know yourself if an amp is substantially underpowered serious damage can be caused to the speakers. Perhaps you should mention this in your posts.
MUSICRAFT said:plastic penguin said:MUSICRAFT said:plastic penguin said:Should be fine with PMCs. Although, (as JD alluded to) with a 30 watt per channel, may struggle at higher volumes.
Hi plastic penguin
All the best
Rick @ Musicraft
Hi plastic penguin
Why wouldn't you pair a Krell KSA-50/S with PL200's?
All the best
Rick @ Musicraft
MUSICRAFT said:I've used Naim's UnitiQute with Monitor Audio's Platinum PL200 speakers and the UnitiQute has coped admirably with PL200's.
plastic penguin said:He has a habit of misleading people.
plastic penguin said:MUSICRAFT said:plastic penguin said:MUSICRAFT said:plastic penguin said:Should be fine with PMCs. Although, (as JD alluded to) with a 30 watt per channel, may struggle at higher volumes.
Hi plastic penguin
All the best
Rick @ Musicraft
Hi plastic penguin
All the best
Rick @ Musicraft
Simple mathematics. Or do you think we're cretins because we don't run/own a hi-fi shop?
This is the last response to you I'll make on this subject.
BenLaw said:MUSICRAFT said:I've used Naim's UnitiQute with Monitor Audio's Platinum PL200 speakers and the UnitiQute has coped admirably with PL200's.
That's a pretty strong (and IMO utterly false) statement. In what way was Rick's comment misleading?
Hi plastic penguin
All the best
Rick @ Musicraft
Hi plastic penguin
All the best
Rick @ Musicraft
chebby said:There are no hard and fast rules.
My 50wpc (class D) M-CR603 was reviewed by Andrew with PMC GB1s (87dB, 8ohms, recommended amp power up to 200 watts and he found it...
"...proved more than capable of both driving them and making them sound rather special..."
And that was despite the M-CR603 being only very slightly more powerful than the minimum (40wpc) recommended by PMC themselves for those particular speakers.
I have heard PMC GB1is and FB1is used on the end of a NaimUniti and sounding superb. (With Jason Gould of Naim - on one occasion - taking great delight in giving it more 'welly' than I would ever dare to!)
There are also a lot of fans of class A amps (valve and solid state) who get great results from speakers with efficiency as low as 83dB despite their amps 'only' being rated at 25 wpc or so.
