Worth upgrading speakers?
David Parkes
13
I have marantz pm6004 and cd6003 with some mordaunt short avanio 1-XR. Worth considering acoustic audio concept 20 or warfedale 121? Will there be an appreciable difference?
any recommendations on next upgrade step?
thanks!
Blackdawn
86
What aspect of the aviano 1 xr do you want to improve ? I think Cambridge Audio gear gels well with Mordaunt short- what about a different CDP?
KidKomet
18
Hi David.
What's your budget/room size and the qualities you look for in speakers in relation to the music you listen to?
BigH
97
I would try the Kefs R100s, cost £600 new but can be had for £550 or less or about £500 ex demo. Try them and see if they are worth it.
ASK THE COMMUNITY
