ISAC69 said:
You are talking rubish , buy a cheap DAC and you get a cheap sound :rofl: . Give me a break .
The Marantz has an internal DAC and not a bad one if this is not good for him he needs to upgrade the CDP or to buy a very good DAC that
is not cheap , the resonable option is to upgrade the CDP .
:help: Firstly, try reading what I wrote before you hit the reply button, otherwise you're just coming off more useless than your other posts. :roll:
Firstly, why is it rubbish to say that you can use a DAC for anything, not just computer based devices as you said?
Secondly, there are plenty of very good quality "cheap" dacs. Also, if you bothered to read what I said, I said buying an external Dac can be a cheap way to upgrade a CD player without having to buy an entire new unit. I didn't say, buy a cheap dac and put it on an expensive CD player. :roll:
