Hello all,
Been having some trouble with my setup and thought this would be a good place to seek advice. The problem is that Ive not long ago moved house, my setup is now in an upstairs room and the bass on my speakers is becoming a little bit woolly to say the least!
The details are: Arcam A85/P85 bi wired to B&W DM603 S3 using CableTalk 5.1 cable. They sit in a room approx 400mm from the rear wall, and 300mm from side walls. I have plugged the bass port with the sponges, but this hasnt made much difference. Could the problem be that I am upstairs? Previously my stereo has always been on a concrete floor and I havent had this problem.
Does anyone have a similar problem, or any suggestions on how to sort it out? The speakers have their spikes in place, so i thought it wouldnt be vibration through the floor - but this is the only explanation I can think of.
Any advice greatfully received.
James.
James.
