Wireless or wired that is the question.
My broadband speed is only 3 to 4 mbs it is wired at moment, if i have it wireless will it affect the speed of my broadband?
Nope, wireless will just affect the speed which your computer connects to your router. Wired it's probably 100 Mbps or possibly even a 1 Gbps connection, whereas depending on your wireless network type, it will vary from between 11 Mbps to 54 Mbps. Whichever, as you can see, it's still substantially more than your broadband connection so won't affect the speed.
Thanks for the quick reply, will get it changed then, less wires ahh joy!
I got wall plugs, they are amazing.
My wireless kept dropping all the time, so got the plugs and its been happy days since.
