Alears said:
I am pretty sure it will. You'd have to check thickness of each.
Not sure why you would want to fit one though as I thought the resin platter of the RP1 was supposed to be better than the glass one on the Planar 3. (Which is why most many owners of Planar 3's replace them with aftermarket acrylic versions).
As you know Alears, I've been working on my Rega for a long time, most of it when reported, one was laughed at as a tweaking excentric. I changed the sub platter to a metal one, damped it and isolated the glass plater with mini hard rubber stand-offs, worked better than the acrylic that I tried. Since then I have incorporated a new wafer thin acylic platter, that, its self, sits isolated above the glass platter, the glass now working as nothing more than a rigid flywheel.
Prior to this, I still found the glass platter had far more musical life than the thick acrylic, the glass platter has a 'real life in the sound' IMHO. I believe the secret is the isolation from the bearing and sub platter. There is more to it than this but thats part of the stoy behind some of my recent hifi exocentrics . . . :cheers:
I have gone even further in recent weeks, freeing up 'music' from the TT and system I neaver believed possible.
CJSF
