shuggieb:idc:shuggieb:
....Personally, I don't know if they make a difference. However, whether they do or don't, what is important is whether you perceive an improvement.
There are 4 possibilities;
1- They make a difference, and you can perceive it (Genuine difference)
2- They don't make a difference, but you perceive an improvement (Placebo difference)
3- They make a difference, but you can't perceive it (Placebo lack of effect)
4- They don't make a difference, and you don't perceive one (Genuine lack of effect)
It is not 1 for the reasons I gave above. Two is true and 3 maybe true as well, which helps to give creedance to 1 when that should not be the case. That is not placebo, it is physics and biology and how there could be minute variances which your dog may be able to detect with their much better hearing, or even a machine, but not a human. Four is what happens with you decide that you no longer believe cable hype, so you lose the placebo etc effects that do make cables sound different, to some people some of the time.
idc,
I'm not suggesting which of the above is true, I'm just setting out what I believe to be the four possible hypothetical explanations. Regarding placebo, given that perception is a result of the interplay between electrical impulses and the release of neurotransmitters through a series of synapses in a multicellular system, then I agree that not only is it placebo, it is physics, biology and chemistry too.
As to whether 4 occurs when you no longer believe hype, that is doubtless true for some, however it is well documented that even unblinded placebos remain efficacious, a phenomonen I've always found difficult to understand. Although it is a useful way of understanding the passion that cable debates often generate; if someone who knows they are taking a placebo can experience an improvement in something as personal and subjective as, say, pain, then I suspect even proving that cables do not make a difference from either the perspective of empirical measurement or from blinded comparisons will not necessarily convince the true believer, and the more robust the evidence, the more it challenges their stated position, the more it will engender an aggressive response.
From a rationalist perspective, I agree with Max that it seems implausible that any form of data loss could be anything other than random, and therefore could not produce any consistent difference in cables.
The question is, of course, answerable. You need a statistician to calculate a sample size that is sufficiently powered to demonstrate difference or lack thereof. You then need to design a double blinded randomised controlled trial where participants are told that they are listening to 2 cables, a and b. You then randomly assign participants to hear either a vs b, a vs a, b vs b, or b vs a. You then have them vote for which sounds best on a number of predetermined scales such as clarity, detail, warmth, etc. You then find out if the differences percieved are statistically more in a vs b and b vs a than a vs a and b vs b. This will tell you if a representative sample of humans can perceive a difference. It will not however, convince anyone who is a true believer or disbeliever as they will continue to believe that either they can hear a difference where the trial participants could not if no difference were shown, or that the trial participants were not properly blinded or coincidentally guessed right en masse, however improbable if a difference were proven, depending on their pre-existing belief. That is why belief is dangerous and cable debates are endless.
Oh, and I asked my dog, but he just licked his bottom then asked for a biscuit.
But then he is a labrador, and I think their ears don't have the special braiding and lining that spaniels have, and I saw in an advert that spaniels are better at noticing instrument separation because their ears hang lower, so it must be true....
I suppose that now you've completed the lab tests, you should give a cat scan a chance!
