will cyrus match my cm1s
audioaddict
114
hi just wondered if cyrus equipment will match my bw cm1 speakers. was thinking of the 8 xpd qx with matching cd transport thanks guys
I had some CM5's with the Cyrus 8vs2 and it sounded brilliant so I'm sure the CM1's would work well with the 8XP et al...
DandyCobalt
203
I have them as surrounds, plus CM8 fronts, with Cyrus pre/Xpower and transport - works a treat.
I think the forward/detailed nature of the Cyrus amps along with the smooth and, at times, laid back sound of the CM range of speakers goes very well together.
audioaddict
114
thanks for all the replies guys . david what would the 8200cdq give me in terms of sound quality ? i was looking down the cyrus route due to the size of the boxes
audioaddict
114
i am still thinking of getting the cdq and matching 8200 power amp but not sure what i would lose in terms of sq going from monos to a single power amp though this would still cut down my box count and id have a smart two box system (depending on whether id get a tuner ) only thing is now ive got my cm1s the sytem is sounding lush:p
