- Jun 25, 2008
- 146
- 0
- 0
I am planning on buying the Audiolab M Dac (when it arrives) and want to check if it will work as follows.
I hope to take the stereo-only output from my Denon AVR 2808 and feed it into the DAC. I can see that I have two optical outs (marked DVR and VCR) and assume I can take this to the DAC. Will I be able to pull just the stereo fronts out of these and leave the AV Amp decoding the rest.
I currently send the phono pre-outs to my stereo amp so really just want the DAC to intercept this part of the signal before it goes to the stereo amp.
The beauty of this is that all stereo sources, whether it is from the Bluray (playing a CD), the SkyHD (for radio) or my airport express should all be able to play via the DAC. I also assume this will bypass the AV amps pre-amp section completely and let my stereo amp handle the pre & power duties.
Any guidance or help much appreciated.
